Using 3.7.9 to produce an audiobook.
First, @kozikowski did you know that the Audacity Article page and the Musehub page discuss using your AudiobookMastering macro, but the OLD one, not the 36 one. It fooled me a minute, and then I found a thread where you posted the new one. 36 worked great, old one not.
Second, I just published my first audiobook on ACX. It took 15 minutes to be approved. Every file passed first time. Thanks so much to whoever created the ACX Check tool! All I had to use were the DeClicker, the DeEsser, 36AudiobookMastering, ACX Check and adding noise, which I discuss next.
Third, I spent a bunch of time researching before I started recording. Thought things were good until I got halfway, which is when I discovered the ACX Check tool. Fails all over the place. Most were easily fixed by mastering, but I was stumped on the noise floor; it said it was TOO LOW! (Side note: I did not discover the Windows setting of the microphone which @kozikowski said to turn off until later. Oops.)
Anyway, thank heaven for this forum, because I found another poster who had the same issue, which is where the Windows setting also showed up, and @kozikowski mentioned creating a new track with just noise and merging them. BAM! Worked like a charm! Although I used a VERY low noise, Brownian at .008 level.
Just wanted to say how useful the forum has been and how much I appreciate it.
