Hi. Thanks for the reply. To respond to your questions:
[Are you sure your EZCAP device has USB Audio output] The EZCAP is marketed as a USB Cassette Capture device. “The USB Cassette Converter is a portable, handheld USB tape player that works with all kinds of tapes. It has an easy-to-use USB connection for converting the music on your tapes into MP3 files…” So, yes, it has USB audio output.
[It also has 3.5mm Audio Jack for analogue audio recording Linein/out or headphones. … Are neither of these giving a good Audio output…???] I checked the analog output from the 3.5mm jack, both with the provided earbuds and with a powered amplifier. There is good audio output from the jack.
[You say “the software” recognises EZCAP as recording device Microphone (USBPnp)…that is the software that came with the player…??] The software I’m using is Audacity version 3.5.1 for Windows 64 bit, which I downloaded from the Audacityteam.org website.
[What does windows Sound setup see it as and what volume levels are set.] Windows recognizes the device as Microphone (USB PnP Audio Device) Provider: Generic USB Audio. The volume levels are set at 100%
[You can goto sound device properties an click “listen” to hear the input as windows sees it, bypassing everything else. … then untick this again when you get it going] There is no “sound device properties” screen in Windows 11. There is System>Sound>Properties for the input microphone, but there is no “listen” link to click. I did click “Test your microphone” with the EZCAP player running and got a readings of 57% and 64% of total volume.
[Then Audacity needs to see it as a recording device and make sure the recording sliders are up] Running version 3.5.1, in the Audio Settings, Audacity recognizes Microphone (USB PnP Audio Device) as the Recording Device. Project Sample Rate is set at 44100 Hz, and the Playback Device is the onboard speakers. The recording and playback sliders are both set to 100%
That being said, no matter what I try, I am unable to get a recording on my Windows 11 laptop. HOWEVER: In desperation, I tried downloading Audacity to my old Windows 10 laptop, and miracle of miracles, I was able to record (albeit at a very low volume) from the EZCAP player using the same cassette tape. So it appears that the problem is that Audacity is not compatible with Windows 11. Using my old laptop is not a viable workaround, however, because the computer is old and slow, and I don’t know how much longer the hard drive is going to last, so I would really like to get this system working on Windows 11 if possible.
