I just loaded version 3.7. I have no toolbar at the top. ie File, view, etc. I have a Mac with version 15.3
Hi new here. any help would be appreciated
New only here, or also new to using Macs?
What you call “toolbar” is the menu bar.
The menu bar is not part of the application’s window. It is at the top of the Mac’s screen. See this image. The orange colour you can see is part of my desktop picture.
If you click the green button, the application window becomes “full screen” and does not show the menu bar any more. You can make it appear (and use it) by touching the top of the screen with the mouse cursor.
You could also click the green button together with the option key - then the application window maximises, but does not make the menu bar disappear…
This applies to all programs on the Mac, not only Audacity.
Thank you so much for your help. I am aware the Mac menu bar disappears until you touch the top of the screen. That is not the issue here. The Menu bar is not there at all.
