No sound when recording
Hi,
I am new to audacity and need some help recording a DJ mix.
My setup is 2 turntables into a Rane TTM56s DJ mixer and a pair of speakers/monitors direct to the DJ mixer as master output.(not the computer).
The way i want to record is to have my Avid Mbox 4*4 audio interface soundcard going to my laptop and have a RCA cable going from the S/PDIF input on the soundcard to the AUX output on my mixer to pick up the sound.
However when i record i am not getting any wavelengths at all. The input device in audacity is setup correctly as my MBox and the recording levels are up so not sure where I am going wrong. I am using Audacity version 2.0.5. The output device is laptop soundcard as i have no speakers connected to the Mbox.
Any idea what i am doing wrong, have i got the basic setup correct and just need to adjust something in the software or have i made a mistake with this initial setup?
Thanks,
Do this little trick and see if there’s anything on that wire. My bet is no.
http://www.kozco.com/tech/audacity/pix/earBudsRCA.jpg
That’s any headphone or earbuds with a 1/8" plug. It won’t blow you ear off with high volume, but it should not be totally silent, either.
