I am trying to record from a cassette to my Mac which is version 10.15.4 Catalina.
I have made sure all the volume options on the converter, the software and my Mac are up (even all being on max) and it all seems to function fine but it doesn’t play anything but external noise when I play back and I just can’t understand why! I’ve tried both USB portals on my laptop and I have checked the microphone is enabled for Audacity on system preferences but still nothing…
Can you shed any light on this? I really need to get this done
Not a mac guy here. Hopefully, you have solved your problem by now. If not, post back here and someone should reply. From your report, I am not clear as to exactly what difficulty you are having.
Is it possible that you are trying to record from your microphone, not from your USB device? You need to specify your USB cassette player in your Audacity Device Toolbar: Device Toolbar - Audacity Manual
How is your cassette player connected to your Mac?
The settings in your Device Toolbar appear to show that you are set to record from the built-in mic rather than a cassette player.
Ensure that you connect the cassette player to the Mac before you launch Audacity.
If Audacity is already running, you either need to quit Audacity and restart, or “Transport menu > Rescan Audio Devices”.
Then look for the USB option in the Recording / Input Device setting of the Device Toolbar. Select that option as the recording device.
After connecting the cassette deck to your Mac, go to Apple menu > System Preferences > Sound > Input. Do you see the cassette deck listed there? “USB” should be part of the device name. Click on it then start a cassette playing. Does the sound meter bounce? If you get this far you should definitely be able to record from the device in Audacity - do what Steve says.
Note: if your cassette shows up in Sound Preferences as “PnP USB Audio Device” (or similar - the key is “PnP”) then you may have one of many problematic cassette-to-USB devices that fail to maintain a consistent USB connection.
