I am using Audacity for digitalizing my old records. It worked for a while and now out of a sudden, when the tone arm touches the record and I push the recording button, then recording starts, but there are no visiable “waves” like before. I did save it as a test. mp3. And when I play it on my computer… no sound. I still have 10 double record albums to digitalize, and I don’t understand what happened. I did not change any settings, etc.
Thanks in advance for your help.
FYI: the record player I am using is a DUAL DT 210 USB. is it possible that the needle got compromized?
Have you verified that Audacity has permission to use a sound device? Windows has this permission to prevent programs from surreptitiously recording you.
Problem solved. I checked the audio setup and noticed that my usb device was not listed. so I initiated a seach, and now my USB device was listed, so that I could pick it.
