I have Audacity 2.0.3 and I’m OS 10.8.3, new user to Audacity, working on tutorial for how to edit an mp3 file.
So far I have successfully imported an mp3 file to play with. When I click the ‘play’ button, I hear the song playing. However, I can only hear the song playing through my computer’s built-in speakers. I do not hear anything in my headphones which are plugged in to my keyboard. If I play a song in iTunes, I hear it in the headphones when they are plugged in to my keyboard.
I have tried adjusting Devices in Preferences. I either lose sound altogether or it does nothing when I switch from Built-in Output (default) to Built-in Line Out or Built-in Digital. I have Logitech headphones, is the problem that Audacity does not support those?
Attaching screen shot of my Preferences settings for Devices.
Soooo. close.
“I have Logitech USB headphones model number…?”
Unless they’re really strange, you should be able to find a USB Something, USB Sound Device, or something like that in your Audacity > Preferences > Devices > Playback: selections.
You should be able to find your headphones listed in:
Apple > System Preferences > Hardware > Sound > Output: Something-Something-USB. That’s the clue what to look for in the Audacity Preferences.
I’ve use a Logitech USB Headset A-00008 and it appears in both places as “Logitech USB Headset” and works well in iTunes and Audacity. I will warn you that mine have a volume control on the right-hand muff. If I turn that all the way down, I lose.
Oh, one more thing. Audacity checks for devices when it starts, so plug everything up and then start Audacity.
Thanks Koz. Yes, I was looking for the Logitech USB name in the drop down menus but was puzzled when I didn’t see them anywhere. Attaching another screen shot, as you can see, it’s not in the list. It is in the list when I check Preferences/Sound in my OS.
Will try restarting Audacity with phones plugged in.
Thanks, restarting with phones plugged in worked!
Oh, and I didn’t list the headphone model as they are really old and I have no idea what they are anymore…
Thanks so much for your help!
Logitech is not the most straightforward with their model numbers. As near as I can tell, their USB Desktop Microphone is called the"USB Desktop Microphone." Nobody’s ever seen a part number.
You can also tell Audacity to go out and look for connections right now with Transport > Rescan.
