Audacity 3.1.3
Windows 10
Turntable Audio Technica AT-LP120-USB
Headset Sony WH-1000XM4 Wireless Noise Cancelling
I’ve been using Audacity with much success for several years to listen, record, edit my collection of vinyl records. I have been using an old low tech wired set of earphones originally bought for making VOIP calls. I decided it would much more fun with better headphones and wireless so I could roam about while recording. Got these for Christmas and VERY happy with the features and sound quality. But…
I get no sound in the headset when recording:
No sound when recording or monitoring
Works fine if replaying an existing Audacity Project
Works fine when playing music on iTunes.
Please someone tell me there is a way to make this work.
Thanks in advance,
Jack
What’s the error message? (I probably won’t be able to help but maybe it will be a clue for someone else.)
P.S.
There is something else you can try - Go through the Windows control panel, find the USB device, and then select [u]Listen To This Device[/u]. If that works you should hear the turntable even without running Audacity or any other application.
