No plug-ins folder?
I dont seem to have a plug in folder, nor an audacity folder, only a shortcut in my programs folder. i’ve tried to download the plug ins and it doesnt save right… Im so confused
Which version of Windows?
Did you download Audacity from here: http://audacityteam.org/download/windows
If so, did you download the installer or the ZIP version?
Is Audacity working on your machine?
What exactly are you trying to do?
See if this helps FAQ: Windows: How do I install Audacity, and do I have to uninstall a previous version first? .
