Despite what settings I use, the program will not record anything. I know my mike is working. And the program was working earlier today.
You can start with which computer and which operating system (pink band over this thread)? Which Audacity, all three numbers? Which microphone, model numbers, and what else beside the microphone failed?
Thank you for replying. Sorry I did not provide the information on my original post, but I am just so upset. I am using Audacity 2.1.1 (I obtained it via the exe. installer) on Windows 8.1-64 bit. My mike is a USB mike (Yeti)-I also tried my USB headset and that does not work either. As I may have mentioned, I tried changing all of the settings, but to no avail. I used the program early this morning and it was working fine.
What are the symptoms of not recording anything - is there an error, if so what does the error say?
Or does recording stall with the red recording cursor stuck at zero? If so, see http://manual.audacityteam.org/o/man/faq_recording_troubleshooting.html#pauses. Or are you recording a flat line?
If you connected the mic after launching Audacity, use Transport > Rescan Audio Devices at the top of Audacity.
Sometimes you just need to reboot the computer. Hold the Windows key, press X then in the menu that appears, choose “Shut Down”.
Set Audacity project rate (bottom left) to 48000 Hz - that is Yet’s native sample rate.
Thank you for replying. Nothing I have tried to date works. I reset the sample project rate to 48000 Hz. No recording. I rebooted the computer. No recording. I tried Rescan Audio Devices. No recording.
What is happening when I try to record is that the red recording cursor moves, but it records a flat line.
Do you see tall blue waves for a few seconds before they revert to a flat line? If so, that is a problem that Audacity cannot write to its temporary directory (Edit > Preferences… , look in “Directories”) or that a cleanup app is deleting your recordings while you make them.
Are you sure you are choosing the correct audio device in Audacity’s Device Toolbar and that you have turned the recording volume up?
Have you installed Skype or some other application that uses audio just before the problem started?
Thanks for answering my post!
Just as a reminder, I am using Audacity 2.1.1, I am using Windows 8.1-64 bit, my mike is a USB mike (Yeti-Blue)-I also tried my USB headset and that does not work either. As I may have mentioned, I tried changing all of the settings, but to no avail. I used the program early this morning and it was working fine.
meeker Posts: 5Joined: Fri Jan 13, 2012 11:09 am
I still have no audio. No, I do not get a blue wave before they revert to a flat line. No, I have not installed any audio software just before the problem started.
Maybe I am not using the correct settings: Currently I have:
MME, Microsoft Sound Mapper Input, mono record (which I want, don’t need stereo), speakers/headphones (output). I have tried changing the settings, but perhaps I am not using them in the correct sequence.
Choose the explicitly named recording device that you want to record from, such as “Yeti USB Audio CODEC” (or however it is named).
“Sound Mapper - Input” is whatever is the current “Default Device” in the Recording tab in Windows Sound. If Windows Sound’s default recording device is currently set for example to stereo mix and you are not playing any audio, or set to a headset you are not using, then choosing Sound Mapper - Input will record nothing.
Thank you for your suggestions. Unfortunately, it still does not record. Would you suggest that I try uninstalling Audacity and installing it again?
There is no need to uninstall, but reinstall it with the “Reset Preferences” box ticked (checked) half way through the installer.
Then when you launch Audacity after reinstall, confirm that you want to reset preferences.
Reinstalling it without “Reset Preferences” ticked would not change the Audacity settings.
The default Audacity project rate will now be 44100 Hz, so if you get quality problems with Yeti, remember to change project rate to 48000 Hz when you record with Yeti.
Thank you so much for your answer!
Tony
So are you now recording blue waves OK with Yeti or the USB headset? Remember to change the recording device in Audacity as needed, and to use Transport > Rescan Audio Devices if you connect the device after Audacity is running.
Thanks for your concern. No, nothing is working!
Tony
You might just be missing some salient step like turning up the recording volume or choosing the wrong recording device.
Make a recording that is a flat line, select a few seconds or all of it and Effect > Amplify… . What amounts are shown in the Amplification and New Peak Amplitude boxes in Amplify?
Also click Help > Show Log… , save the log and attach it for us. Please see here for how to attach files: https://forum.audacityteam.org/t/how-to-attach-files-to-forum-posts/24026/1
Hi Gale,
I want to thank you for all your help. Audacity is working perfectly for me. My problem had nothing to do with Audacity. There is a mike setting in Windows that I did not know about. I set it properly, but it kept going back to zero input; so that Audacity was not getting any sound from my mike Of course, I did not know this. I contacted the Geek Squad, with which company I have a contract. Apparently my computer caught a virus which kept resetting my mike to 0. The Geek Squad got rid of the virus, and my problem is solved.
All this time I thought the problem was with Audacity. Sorry I put you through so much. But I do appreciate your willingness to keep helping me.
Thanks for the update. I will mark this as [SOLVED] then.
