No "export as mp3" option[SOLVED]
I don’t know if it is a right place to write, I haven’t seen similar topic too so maybe you can help me. I have downloaded audacity after changing my sys to windows 7 64 bits and now I have a problem because programme doesn’t show me “export as mp3” option.
I have no idea what I did wrong. Maybe you have heard of similar problems and are able to help me dealing with it.
In Audacity 2.0.5 obtained from http://audacityteam.org/download/windows , click “File” at top left of Audacity.
Follow the menu down then click on Export or Export Selection.
In the window that appears, choose “MP3 files” then click the “Options…” button bottom right to choose the quality of the exported MP3. Your quality choice will be remembered next export.
If you have not yet installed LAME you will need that for MP3 export. Click here: http://manual.audacityteam.org/o/man/faq_installation_and_plug_ins.html#lame .
Thank you so, so much ! :slight_smile:
