no audio 3.0.0
Hi Team
Installed V3.0 onto my windows 10, running Conexant ISST audio on an HP laptop, I can record but when I play back I cannt hear any audio, can see it and settings are correct for audio out but no sound. Tried V2.4 and same issue. All other audo i.e. system sounds , music et. is OK.
Perhaps something to do with this Microsoft bug: https://betanews.com/2021/01/25/microsoft-windows-10-conexant-isst-audio-driver-problems-workaround/
Hi steve
Checked this and the update failed to install anyway so that update has not been aopplied on my machine.
Thanks though for the heads-up
Pete
You’ve selected the correct [u]Playback Device[/u]?
Yes correct device selected
