Newbie and iTunes help - please :)
Hello,
I am brand new to audacity and need to mix music for a dance routine. I have just downloaded Audacity and then logged into itunes from my laptop, I tried to import the songs I saved from itunes but it wont allow me to- it says it is an advance audio coding file, that I need to turn it into a wav or aiff file? I have looked on this forum and tried a few things but no joy. Can anyone help?
Please speak in basic terms, this really isn’t my forte lol :slight_smile:
You need to install FFmpeg.
If you are on Windows, simply download & RUN FFmpeg_5.0.0_for_Audacity_on_Windows_x86_64.exe to install it and you should be able to open AAC/M4A files in Audacity.
You can also use iTunes to convert to WAV.
