New to audacity, recording 2 people at the same time
Hello, I am new and I am looking for some help. I would like to start creating a podcast with a friend.
I have a laptop computer with windows 10. I have 2 headset’s with mics built in. 1 is plugged in using the USB and 1 is plugged in using a audio jack. I would like us both the be on our own track. (so far I can get 2 tracks started) I can’t seem to figure out how to see 2 different mic’s.
I can chose from 1 or the other but can’t attach 1 headset to 1 track. I would like to know if there is a way to use 1 headset on track 1 with level adjustments and the second headset on track 2 with level adjustments.
Thank you very much and if there is something I need to buy in order to do this please let me know.
Blaine
Audacity only supports recording from one “device” at a time.
It is “possible” to create a “virtual device” using 3rd party software, that combines the inputs of two USB mics into one virtual device, and then set Audacity to record from the one virtual device. This can be quite tricky on Windows, and as I wrote, requires additional software such as “Virtual Audio Cable” or one of the “VB-Audio” products.
The preferred method is to use a 2 channel audio device (such as one of the many 2 channel USB audio interfaces), and two conventional microphones.
If you’re on a tight budget, you could sit either side of a single “omnidirectional” microphone, though you would need to be careful to both speak at a similar level, and the room would need to be very quiet.
Thank you for the info.
Is Skype a better option for 2 person recording?
Skype is horrible for recording. It’s much better to get everyone in the same place if possible.
You could split the difference. Gather around the kitchen table and you record your headset on your laptop and they record theirs on their laptop. Combine sound files in Audacity later. Yes, there are some serious problems with that, but it does work.
And just when you’re getting fluffy and comfortable with that idea, unless you’re recording in a studio, your voices are going to cross through room echo. There is no boosting the volume of one, or adding effects to one without affecting the other.
This crossing problem is far less of a problem with headsets as compared with conventional microphones, but still. It gets less. It doesn’t go away.
Try it before you record a two-hour podcast.
Skype.
Normally a rotten idea, there are applications. If you’re both using Skype Services, you can sweet-talk Skype into recording the composite for you and let you download the result later. But. It will be bubbly, honky Skype Voice, not theater voice, and it will be a mix. You can’t make just one person louder or softer.
You should avoid one common New User problem. When you get done performing, Export both of your voices as WAV (Microsoft) 16-bit sound files for protection. It’s a common mistake to Save the performance(s) as Audacity Projects and then edit your brains out until the final MP3 sound file.
What’s wrong with that? If anything happens to the Project, Audacity, the data system or the computer anywhere in the process, you may be back at the beginning with the microphones, speaking the show again. I’m not kidding. There was a recent post from someone who flushed two different voice performances into the mud because of no WAV file backups.
One last New User problem. Do not use MP3 anywhere in the production process. Use WAV and only create an MP3, if needed, at the end. Each time you make a new MP3, it increases the compression sound damage. You can’t stop it and it’s permanent.
If I have 2 people in the same room plugged into an audio interface, the FocusRite, 2i2, do I then plug that into the laptop, which is then chosen in Audacity? I watched a video some time ago on how to do this, then what settings to choose in Audacity, but I can’t find it again! Thanks!
Plug the 2i2 into your computer and record as a stereo show, one performer on one side and the other on the other.
When you get to the end of the performance, File > Export as a WAV file for backup and only then Split Stereo To Mono. That should give you two independent mono voice files (each voice comes out of both sides) for editing and production.
As above in this posting, that’s still going to give you leakage, one performer’s voice into the other, and two copies of the room echo.
People record with directional microphones in quiet, echo-free studios for a reason.
There is a lot to unpack.
I record two people, in stereo with one person on the left and the other person on the right about once a week. To do that, requires a TRS to dual TFS cable. A regular “splitter” cable will combine both microphones into the same audio. If that is what you want, that is fine. If you truly want two separate channels recorded at the same time, you need the special cable.
When we record, we are next to each other, with the microphones close to us, but pointing away from the other person. Both of us get recorded on both mics, but with approximately 80% separation. When played back, you can hear each person, one on the left, the other on the right, with some crossover.
Some people like to hear speaking with just one ear bud. Those people hear us both, but with one voice louder than the other. Such people can set their player to combine the channels if they want to hear them both at the same level.
I would not recommend splitting the combined audio into separate tracks, unless one is too loud compared to the other. Even then, I split them, level them, then put them back together again for editing. It is easier than editing two tracks, even when they are locked together.
Thank you! How do these professional podcasts record constantly with two people in the same room if there is so much bleed?
Thank you so much! How do these professional podcasters record constantly with two people in the same room if there is so much bleed?
I would say that most podcasts are encoded in joint stereo with the voices in mono. Only the music in the podcast is stereo. Joint stereo encoders are smart enough to only record the stereo parts in two channels and the rest in just one channel. It makes a smaller file, while still allowing stereo.
They don’t care about crossover because they are merging the voice audio channels into one.
