I am ready to buy some equipment and get into Podcasting and have found Audacity and starting to learn it.
I am hoping someone can help by recommendations as to equipment I will need.
I have pretty much decided my budget will allow the Blue Yeti Silver Edition microphone, along with a pop/click filter. My stumbling block is on headphones. I have found that the Audio-Technica ATH-M35 Studio Headphones seem like a good choice, but am a bit concerned in that they may not filter the sound out enough to prevent causing a feedback loop while recording (voice mainly).
Additionally, when recording on the mic, does the raw audio file go direct to the computer and get saved on the hard drive so I can mix it later with Audacity, or is there a different process to this?
(I have PCs and can use this equipment on Windows XP Professional or Windows 7 Professional).
Thank you.
