New Export Audio dialog is better in 3.6.1
Just a thank you, not a question.
I notice the export option has been reworked. It’s much better. Clearer.
the new export gui is just confusing, it isn’t helpful at all
What exactly do you find confusing about it?
Just goes to show that you can’t please everyone all of the time. I like the new interface. Doesn’t slow me down at all.
In Preferences > Interface, check “Show Extra Menu”. You’ll get the old “Export As …” commands back. You can assign your own shortcuts to your most-used options at Preferences > Shortcuts.
