Hey DVDdoug - Thanks for that and also for helping me solve the mystery. I’m sure others might’ve just ignored this; I really respect your honesty.
The one I deleted had a few lines of bold test and it had a “style”
Guilty. I added bullets and bolding to help with the sea of text. Will add some of the names below that I’d been worried about sharing before.
Studio condensers are not compatible with the mic input on a soundcard or laptop but there are USB versions.
Does this mean every USB mic should be compatible? I’d gotten the idea that I might need a dynamic mic from the ACX Gearing Up for Audiobook Production Part 1 article. At a really cool studio library a few cities back, I tried out their mic (Rode NT-USB Mini). It had a nice brightness, but the room was 70% sound treated and the mic picked up all 30%.
Analog dynamic mics tend to have low output,** about 20dB lower than a condenser mic and many audio interfaces don’t have enough gain for “normal voice” and a dynamic mic.
I have a softer voice, so no doubt this will be a consideration.
If you get a USB mic (AKA “podcast mic”) look for one with a recording level knob.
Do you have any pointers for where to start with modifying the settings?
The Blue Yeti seems to have a bad reputation
I was planning to skip them based on reviews, but am open to the idea that it might be ok. I have a 2017 MacBook Pro 13 with 16GB of memory (USB-C ports, it’s usually pretty quiet unless I’m running lightroom and photoshop heavily); Bose QuietComfort 25 Headphones (I tried using these in the library and couldn’t get sound from the mic in them, but might’ve been a setup issue - not that I have to use them, just to describe the equipment options I have); and no real space for a big stand/mount in my backpack (used a paper towel roll as my stand with my iphone while editing). Options I am considering (open to others):
Rode NT-USB/NT-USB+ (the latter I guess has 8dB higher sound pressure level and is a 24 vs 16 bit, if either of those make a difference for my use case)
AT2500x-USB
Samsung G-Track Pro
Blue Yeti / Yeti X
Rode NT-USB Mini, AT2100x-USB (looks these are both lack a recording level knob, so crossing off)
Might you have any experience with those?
NOTE - If you record different parts of a book in different environments you probably won’t get constant sound
Yeah. I’ve got a few weeks. Since I’ve recorded (iphone) and edited in audacity for beta listeners, I have a bit more confidence I can get it finished (less than 1.5 hrs of finished audio). Just a matter of getting a mic, setting up the closet and learning how to record with audacity. FWIW, I did try to use a studio to get around all of this, but the guy was a bit of a scammer and refused to let me have a copy of my files at the end of the session. Required the police just to have him to delete the files so he didn’t have my content (and he didn’t delete my nature sound files I’d brought) - so I’d rather have to do a bit more post processing than risk that again.
I know this post is rather long, but I have edited it twice now. First I thought the re-addition of bullets might have caused it to go into another pending status and then maybe the emoji or the link to the article. If I’m doing anything else that’s flagging my replies, I can change!
