Never records, just stutters. What am I doing wrong?
Using El Capitan. But have never gotten Audacity to record and have the updated version. Just sits and stutters. Routing Soundflower input into it with sound activation on. Doesn’t matter what I do with buffer or volumes, never works. Had Soundflower working with Logic Pro but now inextricably does not work there either. Read through all the directions. No change. Any ideas?
Using El Capitan.
On a laptop?
Let’s not worry about Soundflower for a bit. Can you record the laptop built-in microphone? Straight recording, no bells and whistles or fancy controls or tools.
You don’t even have to listen to it. Just get the bouncing sound meters and blue waves that move when you speak.
