I am wondering if someone more experienced with the software could take a look at the audio file and tell me the best way to get rid of this type of click.
The clicks occur in a lot of different frequency bands.
You could try Noise Reduction - you are going to have to do that anyway. You could select and Effect > Repeat a click noise to make it long enough for a Noise Profile.
I can get the background very quiet that way if after a first pass of Noise Reduction I reselect some residual clicks and make those a Noise Profile.
But we don’t know what other audio is there apart from the clicks. The danger is always removing or damaging audio you want to keep.
I am not an audio engineer. Probably one of those will have some input.
