Hi,
I need to increse the treble of my recordings but the audacity i have does not have treble option. Instead it has an option called “bass-boost” that allows only to adjust the boost.What should i do to get the bass and treble option enabled?
Hi,
You are using an obsolete version of Audacity (see the pink panel at the top of the page for more information).
Update to the current Audacity 2.1.1 from http://audacityteam.org/download/windows then it will include Bass and Treble.
Gale,
Thank you very much.Solved the problem
