Hello all,
I am using version 3.2.5.
This is now the second time that the keyboard shortcuts I created disappeared.
Is anyone else experiencing the same?
Is there a remedy?
Thanks!
Hello all,
Is there a remedy?
Thanks!
(New on the forum)
Temporary workaround would be to import your shortcuts once they disappear. (This assumes you export the shortcut XML after you set up the shortcuts)
Not a long term solution but can avoid short term frustration (until you have to do it again and again)
