I’m creating a selection of portions of tunes, usually about 35 seconds long for a pub music quiz I’m running. The objective is to guess the title and the artist. Using Audacity this is not a problem to edit relevant tunes down to the required size. However, some songs use the Title words quite early on. Is there a way to remove/obscure the title only in this situation?
You mean stop the singer from singing the words? You can beep them out. Drag-select the words and Generate > Tone: 400Hz or 300Hz at 0.2 size. That will stop the music, too. We can’t easily split the singer from the music.
