Music Generation Fail OpenVino
I try to use Openvino Music Generation But it fail all time. How to fix ?
(am not good at english sorry)
when I push the Button its will show log =
16:59:52: Audacity 3.4.2
16:59:52: Error: Failed to load shared library ‘avformat-60.dll’ (error 126: The specified module could not be found.)
16:59:52: Error: Failed to load shared library ‘avformat-59.dll’ (error 126: The specified module could not be found.)
16:59:52: Error: Failed to load shared library ‘avformat-58.dll’ (error 126: The specified module could not be found.)
16:59:52: Error: Failed to load shared library ‘avformat-57.dll’ (error 126: The specified module could not be found.)
16:59:52: Error: Failed to load shared library ‘avformat-55.dll’ (error 126: The specified module could not be found.)
16:59:56: sqlite3 message: (1) no such table: project in “SELECT 1 FROM project LIMIT 1;”
16:59:56: Error: Failed to load shared library ‘avformat-60.dll’ (error 126: The specified module could not be found.)
16:59:56: Error: Failed to load shared library ‘avformat-59.dll’ (error 126: The specified module could not be found.)
16:59:56: Error: Failed to load shared library ‘avformat-58.dll’ (error 126: The specified module could not be found.)
16:59:56: Error: Failed to load shared library ‘avformat-57.dll’ (error 126: The specified module could not be found.)
16:59:56: Error: Failed to load shared library ‘avformat-55.dll’ (error 126: The specified module could not be found.)
17:00:13: Error: In Music Generation, exception: Exception from src\inference\src\core.cpp:134:
[ GENERAL_ERROR ] Model file C:\Program Files\Audacity\openvino-models\riffusion-unet-quantized-int8\unet_int8_sq_0.15_sym_tp_input.xml cannot be opened!
17:00:16: Operation ‘OpenVINO Music Generation’ took 0.111000 seconds. Poll was called 1 times and took 0.000001 seconds. Yield was called 0 times and took 0.000000 seconds.
