On Audacity 3.7.7, I have downloaded and installed MuseHub then OpenVino. It all seemed to install OK. If I check the Audacity program files, I can see OpenVINO files in there. But I’m damned if I can find OpenVino anywhere in Audacity in order to open it. It is not in ‘Modules’ to be enabled. It doesn’t seem to exist. Any ideas? Many thanks.
It depends on which OpenVINO you are using. Some appear in the Effects menu, others appear in the Analyze menu.
Whoa!! It has suddenly appeared in both Analyze and effects menu. Weird. I swear I checked many times and it wasn’t in either. Not as if I restarted or anything. But thank you, much appreciated.
