Multitrack recording isn't working anymore - Rodecaster Pro
Hi All,
I was using this program with no issue and all of a sudden it stopped working tonight. I am using a Rodecaster pro.
The device settings I was using were:
Windows WASAPI
Microphone (Rodecaster Pro Multichannel)
14 channels
Speakers (Rodecaster Pro)
Usually this works fine. I was actually using it for a bit today and then it just stopped. The program is no longer recording the multiple channels.
If I switch to Rodecaster Pro (Stereo) it will record the one channel fine. So the mic and cable are working. I am a newbie so I am at a loss as to what to do to fix it. I need to record multiple microphones.
Any help is appreciated. Thanks!
Cash
