WMA supports multichannel and I have another program that encodes it (below), but in Audacity 2.1.2 I can Export most other formats to multichannel but not WMA. It’s set to Custom mix in prefs but in the Advanced Mixing Options it only gives 2 L\R
Any help would be appreciated.
Audio
Format : WMA
Format profile : Pro
Codec ID : 162
Codec ID/Info : Windows Media Audio
Description of the codec : Windows Media Audio 10 Professional - 160 kbps, 48 kHz, 7.1 channel 16 bit 1-pass CBR
Duration : 57s 705ms
Bit rate mode : Constant
Bit rate : 160 Kbps Channel(s) : 8 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 1.10 MiB (99%)
Language : English
Audacity cannot not use the latest FFmpeg except by using the (external program) export choice, but even the latest FFmpeg is still limited to two channels maximum output despite having some WMA v9 support.
To encode other WMA formats, export using (external program) and point to a command-line WMA encoder. lvqcl’s command-line WMA encoder can export as WMA V9, WMA Lossless and WMA 10 Professional. However having tested it, it does not encode more than 6 channels.
The old Microsoft Windows Media Encoder (no longer available from Microsoft) does not support more than Windows XP. Microsoft’s Expression Encoder which replaces it does have some command-line support for video encoding but I have no idea about audio options.
It may be better to export as 8-channel WAV and convert to WMA user some other encoder. dBpoweramp should be able to encode 8-channel WMA if you add the Windows Media Audio encoder - but I have not tested that.
