Deal all,
Please can you help?
Objective:
Open and play a multi track audio file showing the distinct tracks.
Problem
No matter the format I use, Audacity refuse to open these files.
Can play and view these audio files with different tracks in VLC, Olive Video Editor.
Why am I doing this?
a. Recording audio with different mic`s to different tracks
b. Need to measure the delay between these tracks.
c. Thus simply need some software player to show distinct tracks on one page so one can compare these.
Source of Multi track audio file.
OBS Studio
What I tried this far {1.5 days later}
OBS Studio is always recording these distinct tracks.
All files listed below works just fine in VLC, with working sound in audio tracts 1, 2, 3, 4 etc.
Output formats tried. {Error audacity gives for each in brackets}
- mkv, mka: {Audacity did not recognize the type}
media info: Matroska v4, A_VORBIS - mp4 {*.mp4" is an Advanced Audio Coding file.Without the optional FFmpeg library, Audacity cannot open this type of file. Otherwise, you need to convert it to a supported audio format, such as WAV or AIFF.} => MediaInfo: AAC LC, mp4a-40-2
- .opus {Audacity did not recognize the type} ,
.oga {Audacity did not recognize the type} Mediainfo
Detailed media info output for one file as example:
File: “2022-08-23_18-02-20.mka”
General
Unique ID : 200670385068699917478718704694866636318 (0x96F7B5D9DC8B11E192FFE6502F6FCD7E)
Complete name : X:\02-Obs\2022-08-23_18-02-20.mka
Format : Matroska
Format version : Version 4
File size : 95.9 KiB
Duration : 4 s 455 ms
Overall bit rate mode : Variable
Overall bit rate : 176 kb/s
Writing application : Lavf58.76.100
Writing library : Lavf58.76.100
ErrorDetectionType : Per level 1
Audio #1
Format : Vorbis
Format settings, Floor : 1
Codec ID : A_VORBIS
Bit rate mode : Variable
Bit rate : 128 kb/s
Channel(s) : 1 channel
Sampling rate : 48.0 kHz
Compression mode : Lossy
Stream size : 69.6 KiB (73%)
Writing application : Lavc58.134.100
Writing library : libVorbis (Reducing Environment) (20200704 (Reducing Environment))
Default : Yes
Forced : No
Audio #2
Format : Vorbis
Codec ID : A_VORBIS
Duration : 4 s 452 ms
Bit rate : 128 kb/s
Default : No
Forced : No
Thank you,
