Hi,
Is the following information correct with Audacity 3 and 4?
- Multi-channel input:
- macOS: Up to 16 channels. Recording 17 channels or more causes Audacity to crash.
- Windows:
- MME: Up to stereo only.
- DirectSound: Usually up to stereo only.
- WASAPI: Depends on hardware; can exceed stereo.
- ASIO: Depends on hardware and driver. Recommended for reliable multi-channel recording, but must be installed separately due to licensing restrictions.
- Linux: Depends on hardware and driver/audio server (ALSA, JACK, PulseAudio, etc.).
- Multi-channel output: Up to stereo only.
- Level meter for multi-channel input: May be limited or inaccurate. It often shows only stereo, or duplicates one channel, even when more channels are recorded.
- Level meter for multi-channel output: Up to stereo only.
Thanks.
