Good morning I have Audacity 3.7, windows 10 64bit, Intel(R) Core™ i5 CPU 650 @ 3.20GHz 3.20 GHz.
Until yesterday I had no problems, then I installed audio plugins and now when I import the mp3s, they don’t sound good.
I uninstalled everything, cleaned all directories, disabled antivirus. When I import the first mp3 file it sounds fine, I close the program and load a new one and it sounds bad. Subsequently every file feels bad. I open the same file with vlc and it sounds fine
I’m afraid I don’t quite follow what you mean. Can you make a screen recording of what’s happening?
You’re not just importing 2 tracks into Audacity and have them play at the same time, do you?
