MP100 McIntosh Pre Amp
I’m trying to record from the USB output of the MP100 McIntosh Pre Amp but the sound is slow and distorted. The MP100’s output is 24bit at 96khz
I adjust the Audacity settings to 24bit at 96khz but it’s still slow and distorted.
McIntosh are recommending a different recording software but I don’t want to change.
Can anyone help me with the correct settings?
That’s weird…
How far off is the speed? About half speed?
Make sure both Audacity and Windows are [u]configured for stereo[/u]. This doesn’t usually mess-up the speed, but theoretically it could because there is twice as much data in stereo.
You might try 48kHz or 44.1kHz. The speed is related to sample rate and if you play back at a lower sample rate than you record at, it will be slow. Normally the drivers communicate the sample rate between the hardware and software and the drivers also normally make any necessary conversions so you can normally set Audacity to whatever sample rate you want.
This is all normally “foolproof”, especially with USB, but sometimes there is a driver issue sometimes a different sample rate fixes it…
