Hi,
I have some voice recording for hypnotic induction and I am trying to change the recorded voice sightly and apply some effect to make it more “suggestible”. Making it sound like those words are spoken from a “spiritual higher-power” in movies. It makes it sound more powerful and pleasing to the hear. I tried to find some youtube clips to illustrate the effect but couldn’t find any.
That effect is also often used in hypnotic tapes. I think it is some kind of light reverb perhaps with a hint of echo, but I don’t have any experiences in audio effects, which is the reason for posting the question.
Is there a plugin that does that?
Or which effects and settings and in which sequence should I use?
Thank you @Trebor,
that sound you generated does follow what I tried to explain but is not what I am trying to do. I didn’t explain myself very well.
I found this clip that is closer to what I was trying to explain. It has music too but you can disregard it, what I am interested in is the foice “spatial”/spiritual sound effect applied to his voice. This link is already at the time where the person’s voice’s effect is similar to what I am trying to achieve: https://youtu.be/LTmnTEzUeyM?t=255
And also this is another clip similar to what I am trying to achieve (again without the music, just the voice effect): https://youtu.be/wW-OOJ-LPjg?t=584
