Mouse click to zoom waveform
This may not be a bug, but since upgrading to 3.5 the ability to zoom the waveform in with click-left and out with shift click-left seems to have disappeared. In v3.4 the cursor became a lens when hovering over the waveform scale; now in v3.5 it remains the selection tool or whatever it is elsewhere. Did I miss something? Many thanks.
They decided to remove that feature for the waveform view, though some right click options are there: Track Control Panel and Vertical Scale - Audacity Manual
Sad … it was very practical.
You now can Ctrl+scroll to zoom in.
Indeed - thanks! It’s Command-scroll on my Mac and it’s so rapid it’s hard to control. Is there a parameter to set the scroll speed?
