Hi everyone, is it possible to modify all labels’ text at once? I’m trying to get the length of all silence sections in an audio, as shown in the image below, I generated labels of all silence sections with “Label Sounds”, then I wanted to edit every label and append its length to the text, for example, “Silence 01(0.43s)” and so on. How to do this? I really appreciate it if anyone can help!
You can export the labels as a text file, edit it in any way that you want, then import it back into Audacity.
The correct format for label text files is described in the manual.
