mod-script-pipe is missing, can't use scripting API
I’m using the Audacity AppImage in version Audacity 3.0.5 on my Linux machine which runs Fedora 34 x64 with Wayland.
Following these instructions I was trying to enable the python scripting interface to control Audacity form a Python script, but as you can see the module is missing. In fact all modules are missing:
Can anyone please help me to fix that?
The version of Audacity provided through Fedora’s repositories has a bug preventing me from doing 18-Channel multi-track recordings, thus I have to use the AppImage.
Unfortunately the AppImage version of Audacity does not yet support mod-script-pipe.
I’ve logged the issue here: https://github.com/audacity/audacity/issues/2042
The only workaround that I can think of is to build Audacity from the source code (or wait for a suitable version of Audacity to be released).
Instructions for building Audacity are here: https://github.com/audacity/audacity/blob/master/BUILDING.md
If you need help building Audacity, you can ask on this discord channel: https://discord.gg/V6PHB4ZK
I have the same issue as the OP - with Audacity 3.1.3 on Kubuntu 20.04.
The github issue has been closed as of 29 Jan, but I can’t be sure whether that means it’s supposed to have been fixed in some upcoming release. (3.1.3 came out before that, correct?)
Would I be correct in assuming that it’s still an issue with appimage 3.1.3, but could be fixed in 3.2?
Thanks!
Yes.
Release date for Audacity 3.1.3 was 23 Dec 2021
(https://wiki.audacityteam.org/wiki/Audacity_Versions)
The fix was committed on Jan 26th
(https://github.com/audacity/audacity/pull/2481)
I hope so :wink:
I shall radiate hope!
