Missing plugin, even though it says Enabled
What do you mean by “missing”?
Do you see the Nyquist Plug-in Installer in the Tools menu?
I see both Nyquist Prompt and Nyquist Plugin Installer in the tools menu. I tried Nyquist Prompt and there was my subliminals.ny code! So apparently Nyquist was moved from Effect to Tools. BTW, I also upgraded to 2.3.3. Thanks for the help.
Ah ha, you mean the “Nyquist Prompt” effect. Yes, that’s moved, as described in the manual Nyquist Prompt - Audacity Manual
