Missing Leveler [SOLVED]
Good Afternoon
I work for a radio station and I use Audacity daily to cut are commercial and news spot. The newest version that I had to download due to a computer crash no longer has the leveler option. I used this option a LOT :question: . What option does the same job as the leveler or is there a way I can get an older version of Audacity to download?
Thank you very much for your help.
Ricki Taylor
The Leveller effect is now available in the new “Distortion” effect http://manual.audacityteam.org/man/distortion.html
That’s possibly worrying. Were you aware that it causes distortion? If you specifically want that type of ‘soft’ distortion, then use the Distortion effect - the “Leveler” presets are identical to the old effect. If on the other hand you want to reduce the dynamic range (‘level’ out the loudness) without creating distortion, try the Limiter effect with the “soft limit” option http://manual.audacityteam.org/man/limiter.html
THANK YOU
