Missing dropbox link
When I finish recording and save in mp3 format, I used to be able to right click on the file and a box would appear with several options, one of which was “Move to Dropbox” but about 2-3 weeks ago, that option has disappeared from the right click option menu. I need to use Dropbox for audiobooks but the option to do so has disappeared. Any suggestions?
Possibly reinstall Dropbox for Windows ?
It does sound a lot like your system did an “upgrade” to “help you.”
On a Mac, there’s a way to go into the system and see if the application is still there, but I don’t know about Windows.
This may be a good place for a Windows Forum Elf.
