Microphone stopped working with Audacity
Maono microphone stopped working with my Macbook Air. I did a recording with it, then it stopped picking up the sound. Has anyone had this problem and solved it.
I’m a Windows guy but check your Privacy/Security Settings to make sure Audacity is allowed to use the mic.
I have one of those microphones, though I have not used it in maybe a year, since I started using a field recorder. I had that problem once, and the microphone would not work until I unplugged it from the USB port it was in, to a different one.
