Mic not picking up sound after switching laptops
Hello!
Please could someone help me.
I’ve been recording happy on audacity on my very old HP laptop for years using a razor seiren mini microphone for my job as a VO artist.
I recently upgraded to a Samsung laptop, installed audacity and even though the microphone is recognised its just a very low muffled sound that comes out. The blue line isn’t moving according to how loud/quiet I’m speaking.
I just brought a Blue Yeti mic- same problem occurs.
It would just be nice to work on my new laptop, because the HP will give out any day now!
I have the latest versions on both laptops.
Many thanks for reading!
Check your Privacy Settings and make sure Windows “enhancements” are turned OFF.
Thank you so much for replying, but no luck yet! :frowning:
Check you’re actually recording from the external (USB) microphone,
rather than the computer’s in-built microphone.
Disable any recording "audio enhancements " Windows may have applied.
(Windows “audio enhancements” can be on by default in a new computer).
Check the supercardioid Razer Seiren Mini is the right way around.
It will sound bassy & roomy if you’re not taking into the side with the RAZER logo.
Thank you very much for replying
Unfortunately no yet luck after checking all of those things…
I will attach how it looks when recording from old laptop and new…
Mic level slider is in different position.
You star! Thank you so much! Always something so simple!
HUGE thank you for the replies, I really appreciate it :smiley:
