Mic not picking up any sound
Hi! I have a blue yeti - initially got it for asmr but then wanted to record some of my instruments - guitar, piano, cajon, ukulele, etc. I was using GarageBand but it didn’t work well and was told to use Audacity - at first it worked fine with recording my voice- however I was messing around with settings and now I can’t get the mic to record a single thing. I am not sure what I am doing wrong. I have it plugged in- it’s lit up, I assigned it in the settings and in Audacity, I also followed any instructions I found to try to fix the issue. I am so frustrated with this! I can’t figure it out and I’ve had the mic for over a month and a half now and haven’t been able to use it.
A) how can I fix it so at least I can record my voice again?
B) is there any reset all button in Audacity so I can try starting fresh again?
C) what can I do to record an instrument?
Check your Privacy/Security Settings.
Also, the recording volume slider is now “hidden” under recording meters. (And the playback volume under the playback meters.)
