Hello,
I just downloaded audacity on my mac, but the toolbar (file, edit, view …) doesn’t appear at the top of the software.
So, I can’t export my projects.
I need it quickly.
Thank you in advance
(I’m French, so sorry for my bad English)
Hello,
I need it quickly.
Make sure you got 2.0.6 from Audacity ® | Download for Mac OS .
Bear in mind that on Mac, the application’s menu is at the top of the computer screen, not at the top of the application itself. If you resized the Audacity window, this makes a difference.
If the problem persists, quit Audacity, open Finder, choose Go > Go to Folder and type:
Library/Application Support/audacity
Assuming you never had Audacity 1.2 on your machine, just delete audacity.cfg in that folder then restart Audacity.
Indeed, the toolbar at the top of the computer, not the software, (it was not long ago that I’m on mac)
Thank you so much!
I will mark this [SOLVED] then (and make the title a little more relevant).
