Meet audio requirements for audible
Hi there , I am trying to fix my audiobook tracks to meet the audible requirements but when I fix the RMS , the peak level fails in the ACX check and vice versa.
Can you please help find the right numbers and pass the test?
Run the Audiobook Mastering Macro here.
…The “trick” is limiting which “pushes down” the peaks with very little effect on the average/RMS level. Noise can still be a problem and if you bring-up the RMS level you’ll also bring-up the noise. Regular linear volume adjustments change the Peak, RMS, and Noise Floor by the same dB amount.
