Great to see real time effects, but I’m having to also use a portable version of 2.0.6 to get the above to work.
I’m on windows 7
In 2.1 kerovee and Aegean Pitchproof break up and are unlistenable to
and their different settings can’t be assessed in realtime and their is no preview button to as before. Therefore I can’t use either.
mda stereo sliders don’t work - only the default.
There’s a couple of others similar can’t remember which offhand I’ll have to double check later.
Ah yes! uhbik A, D, F etc only work if playback is stopped and then restarted before changing to another default setting.
For everything else that does work:
A big drawback in ease of operation is he GUI Audacity has employed to load the effects. Many of the effects dropdown alternative settings are now buried in a submenu which makes it slower to switch defaults in real time. Also the menu button should be at the top of the dialog because the effect dropdown menu has to often be scrolled down on a smaller screen
