I couldn’t find the answer to the following issue in the following posts:
https://forum.audacityteam.org/t/mbox2-and-audacity-on-linux/32165/1
https://manual.audacityteam.org/man/error_opening_sound_device.html#Check_Audacity_Settings
https://manual.audacityteam.org/man/tutorial_selecting_your_recording_device.html
Here is the troubleshoot:
I plug Digidesign MBox 2 via USB into the computer and without setting anything sound runs perfectly OK.
I run alsamixer
in terminal and I can see:
Card: PulseAudio
Chip: PulseAudio
I press F6: Select sound card
, and the default
setting is already selected.
Esc
for exit.
I open Audacity, and open a mp3 file: File > Import > Audio
I can see the Rate of that track has been assigned to 44100 Hz
Edit > Preferences > Devices:
- Under Interface, Host: ALSA (no other option to choose from the menu)
- Under Playback: Device: default
- Under Recording: Device Mbox2: USB Audio (hw:1,0) and Channels: 1 (Mono)
I play the track and it sounds OK.
I add a new track: Tracks > Add New > Mono track.
I point into the field of the new track, and hit the record button
There is this error:
Error opening recording device Error code: -9997 Invalid sample rate
I don’t understand why recording is not working.
Linux Kernel version: 5.7.9 (16 July 2020)
Many thanks for your help
