Mathmatics of dbFS
trying to understand how to calculate the difference between two sounds. for example, if the first sound is -.1dbFS and 2nd sound is -.01dBFS how much louder is the second sound.
The second track is 0.09 dB higher than the first track.
To calculate the difference, just subtract.
sorry I meant how much louder is it on a linear scale not in dbFS
It’s simple subtraction - The difference is 0.09dB. :wink: (An unnoticeable difference.)
According to my handy-dandy spreadsheet, it’s an amplitude factor (voltage or a digital value) of about 1.01, or about 1% higher.
dB = 20 x log(A/Aref), where A is amplitude (a voltage or a digital value).
Or, dB = 10 x log(P/Pref), where P is power (wattage) (1)
Voltage ratio = 10 to the power of (dB/20)
Power ratio = 10 to the power of (dB/10)
(1) There are different formulas for power because power is calculated as Voltage X Current. And current is proportional to voltage. For example, if you double the voltage you also double the current for 4 times the power. The decibels are the same, it’s just a different formula.
Was there a specific job that needed to know this?
Are you designing a microphone preamplifier? They deal with values down there.
P.S.
Some more numbers for you…
With integer audio, 0dBFS is the highest you can “count to” with given number of bits. 16-bits can hold values between −32,768 and +32,767. (1)
A wave (or single sample) that hits those values on the negative & positive peaks has a peak of 0dBFS.
Back to playing around with my spreadsheet, and considering only 16-bit positive values…
0dB = 32,767
-0.09dB = 32,429
-0.1dB = 32,392
Internally, Audacity uses floating point where 1.0 represents 0dBFS.
You can print the sample values to a text file with Tools → Sample Data Export. But remember that you are (usually) looking at a waveform with (typically) 44,100 samples-per-second so it’s too much data to visualize or comprehend.
(1) Negative numbers can count one-higher because in the binary format there is no negative zero.
no Im not designing a pre amplifier
thank you for the in depth information its a lot to take in but I think I can figure it out. Would you be able to send the spread sheet you speak of?
Thanks again,
I can’t attach the spreadsheet but here are the formulas. Same as above but in “spreadsheet format”:
=20*LOG(A4) Gives dB where cell A4 contains the voltage (or digital amplitude) gain, factor or ratio.
Enter 2 and you should get about +6dB. Enter 0.5 and you should get about -6dB.
=10*LOG(D4) Gives dB where D4 contains the power factor or ratio.
Enter 2 and you should about +3dB. Enter 0.5 and you should get about -3dB.
=POWER(10,A8/20) Gives the voltage gain or ratio where A8 contains the dB (or dB difference from the 0dB reference).
Enter +6 and you should get about 2. Enter -6 and you should get about 0.5.
=POWER(10,A11/10) Gives the power ratio where A11 contains dB.
Enter +3 and you should get about 2. Enter -3 and you should gat about 0.5
