Hi all, I am a Musician and Composer. And I use Audacity for Mastering and editing my Multitrack recordings and making final adjustments to my .wav files, for production! I think it is truly amazing, and I can’t find fault with it at all. And it is free . Thank you people at Audacity.
Regard’s, Joseph.
My Music: Joseph O’Beirne www.soundcloud
TDR Labs “Prism” is a free realtime spectrogram plugin which works in Audcaity3
For multi-track mixing, Audacity probably isn’t the best tool.
It’s fine for mastering as long as you don’t want to use any 3rd-party plug-ins that don’t support Audacity. Audacity’s limiter is GREAT! It uses look-ahead so with most settings it doesn’t distort the waveform.
I use Vst 2 vst 3 plugins with audacity without no problems! So I am very happy, with my audio editing and final results.
