can someone direct me to directions for making a sbd and audience matrix… have done it on mixpad but never on audacity
thanks
mark
thanks
mark
You’re more likely to get replies if you avoid jargon abbreviations. If you mean “soundboard”, please write that in full - this is an international forum and “SBD” is likely to mean nothing in countries where they are called “mixing desk” or “mixing console”.
The short answer to your question is to import the files and use the Time Shift tool to line them up. Use the Mixer Board to balance the levels.
The tracks will be mixed automatically when you Export (http://manual.audacityteam.org/o/man/file_export_dialog.html)
See also: http://manual.audacityteam.org/o/man/tutorial_editing_an_existing_file.html
