First post on these forums, please don’t murder me. Can I apply an EQ curve and make it fade gradually into another curve? For example, applying a curve to the beginning of some audio and making it gradually fade out.
Traditionally, you could do that by creating two shows, one fully equalized one way and one the other. Then fade between the two shows.
It doesn’t say anything in the instructions about being to change equilization on the fly.
http://manual.audacityteam.org/o/man/equalization.html
If it is just for fade-out or fade-in , e.g. see … Nyquist code for "gradual" high-pass filter please - #5 by Trebor
there’s code you can paste into Audacity’s “Nyquist Prompt” effect to do that ,
see the code in the posts … Nyquist code for "gradual" high-pass filter please - #4 by steve & Nyquist code for "gradual" high-pass filter please - #7 by Trebor
