Playing around with it a bit, I’ve found you can get a similar, different effect by applying the ‘am radio’ Equalization effect several times to the same sample.
I’ve had some very strange behavior in the Equalization Effect after playing with it for a moment. Whenever I try to implement a new preset, the graphic representation will change to the appropriate EQ but the dropdown list ALWAYS goes back to say ‘custom’. In other words, I can select different presets, but they’re labeled incorrectly by the Equalization menu. This happens whether I’m using an unedited EQCurves.xml file or not.
It’s not a deal breaker, but it is annoying.
EDIT: It’s a new topic, so I’m not sure if it needs it’s own thread, but here goes anyway: For basic voice cleanup, what kind of basic EQ settings to you pros use? I got some decent results by tapering off the very highest and lowest frequencies…
First off, the equalisation effect in Audacity 1.3.5 is quite buggy, and the effect in Audacity 1.2.6 is quite limited, so if you still have Audacity 1.3.5 or earlier you should upgrade to Audacity 1.3.6.
In Audacity 1.3.6, each time that the Equalization effect is called, it will open with the settings that were used last. The name (“custom”) in the drop down box is not really relevant, but just indicates that the parameters are adjustable. To save an Equalization setting, you should enter a new name (preferably a unique name to avoid confusion), and save it. That effect can then be recalled by selecting it from the drop down menu, even if it was not the last setting that was used.
Filtering out the very highest and lowest frequencies is often a useful basic “clean up” job. You can also use the high pass and low pass filters to do a similar job (this second method will generally do the job better).
