Macro to Remove Tracks
Hello,
I have a project with 14 tracks in it.
I would like a macro to delete all of the tracks except for track 3 and 11.
I can’t seem to find any information on how to do this.
Your help would be greatly appreciated.
Thanks
SelectTracks:Mode="Set" Track="0" TrackCount="2"
SelectTracks:Mode="Add" Track="3" TrackCount="7"
SelectTracks:Mode="Add" Track="11" TrackCount="3"
RemoveTracks:
Keep in mind that your first track is track 0 in Audacity, not track 1 - I think!
Should TrackCount=“4” be TrackCount=“3”? Just wondering.
Yes, but it won’t do any harm. If there is a “track 15”, it will be deleted.
I’ll correct it to avoid confusion.
Done.
Thanks for these hints. I’m trying to do a similar thing. I start with a baby step: select track 4 (partly to check whether numbering starts from 0 or 1). In the parameter of the saved macro the track number to select keeps reverting to 0. (Which seems to confirm that the first track is numbered 0, since, when I apply it, the first track gets selected.)
Why can’t I select track 4?
Also, I don’t understand what the mode means. Why, when selecting, should I choose Set, Add, or Remove?
(I had assumed I would first select a track or tracks and then delete in a separate step. Is that wrong?)
I’d be grateful for pointers and hope it’s OK to reply to a semi-ancient thread.
Cheers, Tim
